Marantz Led light replacement project.
I'm missing something. I just get bi-pin LED's from Randy at irebuildmarantz.com, desolder the old incandescent bulbs and solder in the LED's. Everything works without modifiction, and I don't notice any flicker. I'm not sure what his source is, but it sure seems to work with a minimum of effort. :dunno:
Unfortunately, Randy stopped selling LED's. https://irebuildmarantz.com/catalog/index.php?cPath=2
I did restore and used his products. They were great. I am sure there are other reputable LED sellers, but his products were of good quality and his customer service was great.
No, we're talking fuse-style lamps here. 1/4"x1-1/4" (32x6 mm) size.
Tjerk, 9ZZ
Ahhh, OK. I guess I have the same experience with the fuse LED's. Put them in and they work. I know that early fuse type LED's were polarity sensitive. But I think newer ones have built in circuitry to make them work in either direction. So far, it's been plug and play with Randy's LED's.
Wow! Did not know that. Dgwojo has been selling lamps of all kinds for a long time. I wonder if he has the same LED's Randy had.
I am fairly new in the hobby, but what I liked about Randy was he responded to product questions very fast and offered a ton of information to a newbee. I also liked how his LED's for "Stereo and Dobly" were red.
Well, lots of times has this thread been resurrected, so allow me to kick it once more! This thread has been fascinating, as much for the changes in tech evidenced by posters' experiences over the decade it has been added to! I'm going to do an LED replacement on a Pioneer SX-626 (sorry Marantzers!) and am reading as much as I can about voltage drop resistors and diodes. EchoWars initial post and explanation regarding voltage drop resistors and 4004 diodes is fascinating and informative. I'm curious if I should do this with my situation. I know the Stereo Indicator bulb conversion needs a higher ohmage reisistor...I've read that folks still find issues with resistors up to 470ohm, with one poster on another thread finding the flicker was eliminated on that bulb with a 2k resistor. I have bare wheat grain bulbs (warm white) as well as fuse-type replacements, sourced raw at Parts Express. I'm thinking I should just plug 'em in and see what I get, then tweak 'em. The wheat grains I figured a 1/4 watt 220 or 470 ohm in series with the positive lead is enough? Would you put a 4004 diode in series between power and resistor? Or would you, as Steven Tate did, just plug and play? Can I wire up the bulb with drop resistor and gator clip the leaded LEDS to the pins the original lights are still hooked up to, in order to see the effect, or would this be inaccurate? Thanks for your thoughts....
Randy at irebuildmarantz.com did package up a plug and play set of LED lamps for Marantz receivers. Someone posted that he no longer was selling them. You might PM him (runningdog) and ask your questions. He can at least tell you if any mods are needed. I have done many units with modern LED’s and no mods. But it would be interesting to know if there are potential problems with that. My understanding is that the latest bulbs have built in components to compensate where needed.
There are in general two sizes of LED's 3mm and 5mm available. Most indicators are 5mm where the dial pointer is a 3mm.
I would sand the round top flat and scuff up the clear lens to help in diffusion of the light.
You will need to know the voltages they will be operating under.
Used a LED calculator like this.....https://ledcalculator.net/
Solder the resistor and heat shrink the work.
I show a single LED at 8v uses a 270Ohm in series.
On the fuse style of lamps just buy the 8 volt ready made.
A diode is used to block unwanted flicker. I never bother for it does not seem to worry me.
I have used for STEREO indicator CCR so no need to worry about DC variation thus resistor value . Simple part the only drawback is the size of the package , but I was able to solder it. The linear constant current regulator (CCR) is a simple, economical and robust device designed to provide a cost effective solution for regulating current in LEDs (similar to Constant Current Diode, CCD). https://www.onsemi.com/products/power-management/led-drivers/linear-led-drivers/nsi45015w
Nice! I had read that scuffing the bulb helps "mellow" the brightness, rendering a more "natural" illumination. And that calculator is a handy tool. Is the voltage drop the fV, or is it LED voltage (12v) minus the fV (3.3 with warm whites?) or is it the original voltage of the bulb being replaced (6v stereo indicator bulb) minus the fV (3.3)? And finally, This calculator is the first time I've read that the limiter resistor is in series with the negative (-) lead...I had read several times of people soldering in the resistor to the positive (+) lead. Thanks Oerets!
Thanks for the suggestion. This is used by some in place of a voltage drop resistor? Since a resistor can just be easily tucked into the heat shrink, I'm inclined to stick with that, but I am curious about that CCR.
The FM and stereo are LED's and Muting is incandescent.
This is what the install looks like.
Used 270ohm resistors.
Parts Express pack of five - LED Fuse Lamp for Marantz Sansui Kenwood Yamaha Sony - Cool Blue 8 Volt 5 Pack
Part # 070-122
LED Fuse Lamp For Marantz Sansui Kenwood Yamaha Sony - Warm White 8 Volt 5 Pack
Part # 070-121
