Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
That would be good info to know.
To the OP, have you read through the service manual? I've never owned a 1070, but not all manufacturers state in there service manuals to set the DC offset to 0. Anything up to 30mv isn't bad.
Those trimmers Marantz used in the 70's didn't age well. I've run across enough of them that wouldn't hold bias or DC offset when adjusted to spec.
They would slowly drift out of spec. I just replaced them on sight with either single or multi turn Bourns trim pots.
So +/- 5mv is where it should be set then. It's been ten years or so since I worked on any Marantz gear. I didn't think it was 0mv.
I used to restore and collect earlier Marantz equipment through '74.
Is there any significance in the specification mentioning the use of a VTVM vs. a voltmeter ? I seem to remember (from long ago) that a VTVM usage has an affect on the reading (?) .
Use of a VTVM was because at the time, measuring low voltages (like 10 mV) was nearly impossible and not accurate with a regular meter. DMM and modern equipment has changed all that. VTVM should have no affect on the reading. My 2 nickels.
I had issues on my 1070 with glue covered resistors in the circuit going high resistance and preventing the DC offset pot from being able to adjust to zero.
