MarantzRefrb
I use the Peak Atlas DCA75 to spot bad transistors, and the Peak Atlas ESR70 to spot bad caps. Freeze Spray is good too for finding bad transistors, if you spray the bad component the sound can change, indicating a bad transistor, or cold joint. Use the Ohm setting on a DMM to test resistors to see if they're in spec.
