Your other photo was better because you wrote all over the wires that I would want to look at with yellow circles and AB.Can you tell me which of these correspond to the original +, −, and common terminals of the dual capacitor, and specifically where the small red and large white wires should go on the two replacement capacitors?
The capacitor will hold a voltage for an indefinite time, even with the power switched off and unplugged. You may have 45VDC on the terminals which could give you quite a shock if you touch them, not to mention potential for damaging other components.
That’s really helpful, thank you! Mine still has the original ground strap, and I’m trying to figure out exactly how everything was connected before I put the new caps in.I restored two of these amps. In one I moddified the existing ground strap and used screw top capacitors, and the other I used a piece of copper plate, drilled holes it it for the cap leads and wiring, then ran a wire for the ground.
Ya, just follow the picture he posted. Ive also soldered crimp on ring conectors to caps to make attaching multiple wires to the leads like the one in the picture below. There are enough boles in the bottom of the chassis to attach and arrange cap clamps also.That's not right. Just compare my picture to your photo and wire it the same way.
It's VERY simple. Do you have a problem following my diagram?
- All red wires go to the + terminal on the top cap (I am assuming that those red wires are connected to the + terminal of that cap?)
- All white wires go to the - terminal on the other cap (it looks like you have it connected to the same cap as the red wires - not correct. They need to go to the other cap)
- Connect the black wires with the metal strip onto the - terminal of the top cap
- Connect the metal strip with a wire to the positive terminal of the other cap.
You just need to make sure that you have the + and - terminals of the two caps connected correctly.
You should rotate the caps so the terminals line up like my diagram. Yours are in a random position???
The photos are too blurry to see any detail to tell what the orientation of each cap is.
When you take a photo, mark which terminal is + and which is - on the top of the cap so I can see it.
In your drawing that's pretty much how I used the existing ground strap in the one amp that I used screw tops. I notched the end of the plate to fit the screw on the cap, and added a short jumper wire for the other cap's ground screw.That's not right. Just compare my picture to your photo and wire it the same way.
