I picked up an 18 (18-3012) from @nolasally and it needs some work.
What I know so far
Bias will not come up to .08 volts. (08/06/2017)
Does anyone have a recommendation on a sub for the fet. I have seen 2N5116 or 2N5114 use here. I see where people have used TIP47, 2SC2611, 2SC2371 or KSC3503 for Q1202/3/5/6. If someone has experience with one of these your input would be great.
What I know so far
- Scope is dead
- Voltages to the scope board are good
- One of the fets Q1201/4 had been replaced with a depletion mode mosfet.
- Scope driver board done. Found bad vertical trim pot. Scope is now working. (08/06/2017)
- FM dead
- All tuner boards have good voltage to board
- See post 15 (07/09/2017)
- I see tuner signal at 5B on the MPX Oscillator board. I tracked the signal to the gate on Q510. (07/17/2017)
- I have very low sound on FM (07/18/2017)
- Swapped limiter. Better volume still distorted (07/23/2017)
- Swapped MPX boards tuner mostly working (07/25/2017)
- FM stereo is distorted in right channel. (08/06/2017)
- Installed trimmer R328 FM muting now works. Picture add post #85 (08/10/2017)
- Swapped Q605 and Q606 the issue moved to the left channel. I need a sub for 34-1012. (08/21/2017)
- Replaced Q605/Q606 with new 2N5460s and FM sound good. (08/26/217)
- Right channel only work in left + right or with high blend engaged
- Cleaned all switches and jack and all is well with the right channel.
- DC balance trimmers will not move. (08/06/2017)
- Dismantled R1016s cleaned they should now work. (06/05/2021)
- Bias will not come up to .08 volts. (08/06/2017)
- I have learned a lot since I put this one on the shelf. The amps have a lot of iffy repairs that will need to be reworked. (06/05/2021)
- See post 97
- Replaced speaker relays. (02/21/2022)
