Marantz Model 7c Restoration
jpk000
Hey folks, I recently acquired several pieces of Marantz equipment, which included models 7c, 7t, 8b, and 15. My grandpa used to own a drug store and kept one set at the shop. Anyway, I've been using the 7t with the 8b and it sounds amazing. I've tried the 7c too and I can hear that smooth time in there, but it clearly is in need of some new caps as that tone is patchy. Also, the rca plugs are very sensitive and getting a good connection is a struggle. Has anyone had any experience restoring the 7c? I know it highly valuable and will hold off until I get a pro to restore it if need be. Either way, I'll be keeping it as my own treasure and am not interested in its potential sale price or collector value at this point.
I'll post pics once I upload them to the computer.
Thanks!
Welcome to AK and to the Marantz forum! Might I add: :jawdrop: I have not worked on a 7C but it is worth it for sure, and especially if you're keeping it.
A Twin Cities option to service your stuff is Dave Olsen at HiFi Sound in Minneapolis. Dave's done work for me and I've been satisfied.
I have no affiliation with him other than having him do work for me in the past, just passing it along:
http://hifi-sound.com/
There are also members on AK who work on stuff. Post some pictures and ask questions and they'll chime in. Good people from my experience here on AK.
Hold on to all your Marantz pieces and enjoy them.
Have a 7c and worked on a few....
Do not, repeat, do not replace parts without absolutely having to on the tube units.... Every part that is not original will affect the value.. With that said, a broken unit is worth even less....
The tube units should be treated with the attention of a museum piece.
I would start testing the tubes and cleaning the sockets, then the rest of the unit.
Jk
I appreciate the welcoming and thanks for the responses!
Don't worry jstang, I've only opened up the top of the preamp to look for signs of wear. I think I may have been the first one to look inside since it left the factory. The innards look pristine save for a thin layer of old dust. No cracked caps that I can see. It still has 6 Telefunkens plugged in. I've tried swapping a few out with tubes from my guitar amp that I know to be good with little effect on the sound.
I'll post photos tonight. I've also got the original receipt and a letter from the shop in Montana written in the '60's talking about how these Marantz pieces are top of the line and sure to be the best available for at least a few more years.
I've uploaded some photos of the 7c. The wiring is beautifully done.
You have some excellent and very desirable pieces. I'm glad you appreciate them, coming from your own Grandfather is even more special.
I lusted after a 7c for a long time but they were expensive and I didn't think the sound would match the price but I was determined "one day". That "one day" happened a few years ago and to my very pleasant surprise, it sounded really good. There is some magic in that preamp!
Get yours up to spec and be prepared.
Very cool pictures, thank you for posting them. Restoring your 7c is a job for someone with experience with them.
A little Howard's Feed-N-Wax will help that cabinet. That's all I can help with.
Just for design comparisons sake, here's my 7t a while back.
attachment.php
In the 7c, there are some construction techniques, circuit design and components that create the magic....
Thanks Hull Rust, checking out these photos gave me a clue of just how intensive a restoration this could be. I will probably check out Hifi Sound - they are only about 2 miles from me. May be a while as I'm sure it won't be cheap.
Check out these photos - the original receipt and letter from the dealer. The 7c, 8b, and control box cost only $555.00! Although, that was in 1964 so still not cheap, but no where no where near their value today.
The best part of the letter: "We also are informed that there will not be any changes in these basic products in the current 2 years (1966). All of this, plus a new franchise structure from Marantz, seems to indicate to me that this is really going to continue as the top amplifier company for some time."
If you don't have them, manuals and other information are available online. Original manuals show up on eBay, but you can download them for free at hifiengine.com:
http://www.hifiengine.com/manual_library/marantz/7.shtml
(note the above is for the 7c, not 7t)
http://www.hifiengine.com/manual_library/marantz/8.shtml
http://www.hifiengine.com/manual_library/marantz/15.shtml
You've got some fantastic pieces, and that they are from your grandfather makes it even more special, as was said earlier on the thread. Great family history, and as you get older that stuff matters more and more, it seems.
You've got a wealth of information here on AK, many extremely knowledgeable folks here willing to help.
Wonderful pre-amp - Great that they are staying in your family -
I recently partially restored three for a friend - some photos in the thread below that you may find helpful no matter which way you go. My two cents are to proactively replace the parts that go bad with age with modern components, particularly the power supply and coupling and bypass caps at a minimum, and check the resistors, I found 2-3 in each unit that were off. That is assuming you are planning to actually use the unit. I understand that completely original ones MAY be more valuable if left alone, but in use, at best they will not sound as good as they could, and at worst could cause damage. YMMV
Best luck on your system - you have an extremely fine set of gear - some of the best ever made.
Marantz 7c re-fresh
I have to say: when you get everything rehabbed, you'll have a killer tube setup and a pretty darned impressive solid state setup.
Hmmmm..... Failed components should be replaced with a part that is as close to original as possible. Slightly out of spec parts? May have been that way from day one.
One thing that is garrenteed... 7C's that have had whole sale cap replacements with modern caps and with bypass caps added.... Those modifications my have given some one some gradification, but they sell for less for a reason. Check Ebay...
The caps used in the 7C from the factory were some of the best sounding units.
I would throughly test the unit, touble shoot any problems and replace only what is absolutely proven to be bad.
If you are looking for a unit to use every day for hours a day and that is what driving you to widely replace parts.... You should consider buying a modern unit.
Would you buy an original 1970 Hemi Cuda and then try to turn it into a daily driver with modern parts? If you want to hot rod a daily driver, the '70 Hemi Cuda is not the best choice.
By the way, I have proactiviely rebuilt solid state Marantz units...but never 7c.
jk
