Still getting a hang of these speakers, and I don't know what compromises - if any - that the modification that was done to the voice coil has impaced the original sound, but what I can say is...
WOW!
I am listening to Sonny Rollins' Saxophone Colossus...the volume knob is on -38 (equating to around 9 o'clock)...and I am getting everything I need...VERY full bass...that typical open, smooth Ohm sound...and I don't even think I've gotten the placement right yet. Simply fabulous.
The 6moons article was right...LeGall has figured out the voice coil issue (he said he experimented with his A's with 5 or 6 placements until he found the one he liked)...if you can find a pair of F's that only needs a refoaming and sound coil/spider work (the cones on my F's are in great shape), what you have to do is BEG him to do the work for you.
I am very happy.
The post you have quoted was posted over 10 years ago, and it's author hasn't logged on for nearly 5 years, so I doubt you will get a response.Are you still using the 919
What speakers do you use on the 919?The post you have quoted was posted over 10 years ago, and it's author hasn't logged on for nearly 5 years, so I doubt you will get a response.![]()
I'm BACK...The post you have quoted was posted over 10 years ago, and it's author hasn't logged on for nearly 5 years, so I doubt you will get a response.![]()
Good to hear your F's can be driven by the 919's. I looked at the specs of the 919 and the minimum speaker impedance is 8 ohms. The F's are 4 ohms. Just be careful and not overdrive the amp into half the impedance it was recommended for.I'm BACK...
Still using the 919 and F's. They are the only things right now that are still OK in my rig, tho. I have 3 issues:
1) My Nak 580M has been on the shelf for a WHILE (it needs a lot of work);
2) My Tube Research Lab-modified (RIP Paul Weitzel) Marantz SA8001 has stopped outputting sound (the disc/laser seems OK):
3) My Music Hall MMF-7 needs to have the cueing arm adjusted (it doesn't work in the runout groove)
I just semi-retired, so I am driving to Music Technology in Springfield VA to work on all three. Gotta get the rig back in fighting trim. At this point, the only things that DO work are the AU-919 (thanks,
EW - wherever you are), and the F's (oh, and the TU-919).
Peace.
