Another thought, can you measure plate to plate resistance? I'm sort of wondering if perhaps the fail mode isn't plate to cathode but plate to plate.
Yeah thats easy just move the jack from cathode to either 4 or 6 whichever isn't in use.
I'm comfortable running this thing up to 1500V for the GZ34 now, the arc detection seems to work perfect. I'm not quite sure what to make of the arcs the machine has reported so far, though. BTW, the arcing is not visible since it cuts out so quickly. Seems to be safe.
New PSVANE Horizon tube arced one at 900-something volts, but on the 2nd attempt tested fine at 1.5kv (I only tested one diode so far - trying to save these for a video im working on)
The Eico Mullard when run up to 1500v measured 273/258 Mohms IR and did not arc
Both JJs arc'd. The first one 4-8 passed but 6-8 arc'd @ 1234v, but passed on the 2nd attempt and any further attempts after that (tests perfect in Roetest after the fact just in case)
The second one 4-8 passed but 6-8 arc'd @ 1337v, on the 2nd attempt it made it to 1500v but arc'd at 9.1 out of the 10 seconds into the test and aborted. It then passed the 3rd and 4th attempts fine.
Perhaps the arc detection is set too fast, it's on the fastest setting (3uS) there is a 10 and 30uS option. Or I wonder if it's some sort of impurity in the tube that gets zapped off the first time it saw that kinda voltage because I can't get them to continue to do it.
I also tested a 5r4gy for the heck of it, those are rated at 2800piv. It seems to be reflected in the results, I only tested it at 1500v but it's IR was 58/62Gohms which is a lot higher than any of the GZ34's have read.
EDIT: tested one of the JJ's from plate to plate. The machine said arc at .9 seconds into the 10 second run after reaching 1.5kv, but I ran it two more times and it registered as 10Gohms each time. I may need to adjust the sensitivity..
