MC-2105 refurb
UPDATE: The power supply rebuild was successful - dim bulb as expected, no magic smoke. Voltages are all within spec except the 90 volt rail, which is a bit high at 106 VDC. Should I be concerned about this? Mac states a 10% tolerance in their specs, this is a bit over that. Would the fact that the driver boards are out of the amp have any bearing on this? Many thanks again for any thoughts!
More fun emerges… I’m moving on to the input board next, finding a couple of unexpected surprises.
I’m the original owner of this amp so you’d think I’d know its history. But all the electrolytics on the input board are Nichicons, which probably would not have been original to a ‘74 McIntosh amp (please correct me if I’m wrong about that.) So my memory must not be reliable because apparently this board was recapped at some point and I just don’t remember it. Sorry for the digression.
What’s also odd is the two big-ish (reservoir?) caps on the board should be 640µF for an amp of my vintage but it currently has 470µF parts in it. Also unexpected is the related dropping (?) resistors (R9 & R10) that are supposed to be 3.3k are 2.2k, and they appear to be original. I’m inclined to replace all this with the factory spec’d values but I’m not enough of an engineer to know if that’s a good idea, or if McIntosh maybe did this for a reason. I know there were many undocumented changes over time, maybe this is one of those? Or maybe the tech who recapped it used what he had that felt “close enough” to him at the time? I would have used the very reputable local guy whom I wouldn’t expect shortcuts from, so it’s a bit of a mystery.
Bottom line though, should I revert to as close to the factory spec as possible? Everything else matches the schematic and even the old carbon comp resistors mostly test in spec (still!)
I had the same thoughts on my refurb, original amp, also 1974, same pale blue nichicons and yes they are original and you can confirm this with many photos online of the same exact caps, and you will see them with the 470uf value.
I can't comment on the resistor value difference as I left mine original and they escaped scrutiny.
I did use film caps instead of the electrolytic 10uf.
Ok great, I appreciate the confirmation on the Nichicons. For a minute there I thought I was going crazy… The resistors are still well within spec so I’ll probably leave them alone.
UPDATE: (if anyone is still following along)
After running a baseline scope test with the rebuilt power supply, I found asymmetrical clipping in one channel at about 80 watts. Replaced the electrolytics on the suspect driver board and that cleared it up (on removal the 330uF cap tested bad.) Next step is to do the service bulletin upgrades and replace a few resistors that have drifted out of spec. The DC offset tests very low so I’m not going to mess with the differential pairs, but resistors in the voltage divider circuits are being replaced with matched sets.
It’s clear from date codes on transistors that my amp is from ‘75, not ‘74 as I had thought. Many resistor values on the driver boards are significantly different from the last published 2105 schematic. I’ve been told by a reliable source that my boards are more like the 2300 boards of that era and this is consistent with it being a late production 2105.
Onward and upward… I’ll post another update after the driver boards are done.
Sounds like it’s going well!
It could be even later than you think. I have one of the late 602s, and the output transistors were over a year old before they ever saw production. I don’t think that McIntosh really worried much about carrying inventory and bought in batches, in some cases because they were special screened and special part-number printing they needed to order minimum quantities.
You probably already know that the 2300 was very much like two 2100/2105s put together and although the driver boards aren’t identical, … they’re a very similar design.
Yes, I was aware of the similarities in design between the 2100/2105 and 2300. And also that Mac had some reliability issues with driver boards that showed up in 2300s as a result of the greater stress put on them (hence the FSB,) and that some of the fixes were incorporated into production of 21xx models as well. And that much of this wasn’t really documented by the factory. It’s been a great learning experience!
My amp is definitely a ‘75. I bought it through an employee perk program while working at a McIntosh dealer, and I left that job in the fall of ‘75. I no longer have any of the paperwork from that - 51 years and a few things are bound to go missing…
FWIW, I’ve tried to date the amp from the serial number. There apparently was a database online at one time where you could do this - when I tried a link, it was dead…
I would love to find a serial number decoder for McIntosh gear, but I don’t think that there is one. The closest that most of us get is from the date codes on the components, latest one is the winner.
Here is a pic of my recapped input board. Hoping it helps. My resistors also were all still in spec at the time. The amp is currently sounding great.
I have purchased a repro board and populated it but have not put it in. I need some equipment to benchmark the amp before and after the swap to see if and how the specs change. So for now waiting.
Below is the board that I have not tried yet. I put inserts for the transistors so I could try a few different ones and see if there is a measurable difference. If one combination seems to outshine the rest then I will remove the inserts and install the transistors directly on the board.
Great Amp. Good luck with your updates/refurbs.
Thanks for the feedback on the input board. Mine has a few resistors that are out of spec but no other issues. And of course the electrolytics will all be replaced.
I’ve been working on the driver boards first and have one complete and tested (getting 119 clean watts from that channel.) There were some resistors that had drifted that I replaced with 1% metal film, matching actual values as closely as possible channel to channel, especially the voltage dividers. The FSB is also complete, and I replaced the 5 watt resistor with an 8 watt unit, spaced off the board, for better heat management. As I mentioned above, the DC offset tested very low so I’ve opted to not mess with the differential pairs at this time. Also, I have learned that my boards are very late production units and share many component values with the 2300 boards. Photo attached.
IIRC the 043-899 boards are the later ones, same in my 2105, there were two P/Ns in the 210x amplifier.
Looks to be in good condition, no toasted resistors, good stuff.
UPDATE: the input board went smoothly, replaced all caps and several out-of-spec resistors. Bench testing confirmed all is well - the amp is still putting out power that’s slightly over spec before clipping, and the channel balance is excellent.
I finished up the meter board this morning, nothing much to report - replaced caps and four resistors that had drifted. Will be testing that work and calibrating the meters this afternoon. I’m waiting for some LED panel bulbs that were recommended, they’re due on Tuesday. I’ll use them if I like them, otherwise I have new incandescents as well.
Now that it’s nearly time to button things up and get the amp back in service I have to say the rebuild was overall a very satisfying experience. Once final testing is finished I’ll write up a recap (no pun intended, again!) in case anyone is still following along. Many thanks to everyone who has given suggestions, this is a fantastic community!
