Hi,
Upon removing my amp from it's cabinet to replace a burnt out bulb, I discovered one of the main filter caps was leaking (fluid actually on top of cap), and it rattles! when shaking. Amplifier was seemingly working ok otherwise. They test as: 34,000uf/0 esr and 30,000uf/0 esr (Mepco labelled as 38,000uf 60vdc 85c -10%) These are probably the original caps around 45 years old!
So I am in the market to replace the 2 caps, the only ones I can find on Mouser/Digikey with appropriate dimensions and capacity are:
Kemet ALS70A513NF100 51000uf 20% 100V 85C 20000h 105mm $91
Kemet ALS80A433NF100 43000uf 20% 100V 105C 9000h 105mm $96
Chemi-con E36D800HPN473ME92U 47000uf 20% 80V 85C 2000h 92mm $56
Chemi-con E36D750LPN393TE92U 39000uf 20% 75V 85C 2000h 92mm $54
Both are good brand names afaik. I am leaning towards the 51,000uf Kemet's, but is that going to be too much inrush stress on the transformer? Otherwise the 47,000 Chemi-con. I am not an electrical engineer!
Thoughts?
Thoughts?
