I did some more voltage measuring today and I think the amp still has an issue.
DC offset is 9mv in the left, and 35mv in the right.
I also tried to take a look at the bias voltage. I measured around 45mv at the Emitter of Q124 and also 45mv at the Collector of Q126. That seems correct according to the schematic, but when I measured at the Emitter of Q123 and Collector of Q125 I only measure around 16mv. This seems too low.
I swapped output boards between channels to see if the bias measurements would follow the boards, but when I powered up on the DBT the bulb stays bright. If I swap the boards back to their original location the bulb goes dim and I measure the same bias voltages as I had earlier.
I also tried with one output board installed at a time, and the only time that the DBT stays bright is when I have the output board from the channel with proper bias readings installed into the channel that originally measured low.
In other words the output board that was repaired in 1997 keeps the DBT dim when installed in either channel, but I only measure 16mv at the E and 16mv at the C in whichever channel I install it in.
The output board that looks original/untouched measures 45mv in its original channel and keeps the DBT dim, but when I install it into the channel with the mj15003 output transistors my DBT stays bright.
Any suggestions?
Any suggestions?
