The service manuals in the Akdatabase and hifiengine site do not show the many changes and upgrades Mac made to these amp over the decades.
I would start with contact Mac parts and order a schematic so you have a roadmap in hand to sort through this.
The fan coming on "early" can happen for a few reasons, one really bad.
If the thermal sensor is more sensitive, has a lower threshold by a few degrees, it will switch on one fan earlier......not a big deal.
If you speaker has a electrolytic cap in it's woofer circuit.....ie a Zobel network and it gets leaky it can draw more current from one amp causing it to run hotter than the other.....you can swap the one speaker from one amp to the other to test....might hurt your back but not not smp critical.
Then the big one, Mac had problems with the predriver transistors for over a decade with these amps. In the late 70s they came up with the 3rd version and had a policy of updating anyone one of these that we took into service or came into a amp clinic.
Since most of these amps were not subjected to pro type abuse and were to darn heavy for owners to bring to a clinic, many never got upgraded.
As the PNP predriver transistor was a critical component in establishing the NPN driver to " act" like it was a PNP device and was therfore a really critical part of the Szikali or coumpound part of the output stage when it would go wonky the amp would overheat and usually takeout a number of output transistors. Sometimes all of them.....
This repair gets expensive.
So we always ask owners to remove the top cover and get us a picture of the driver cards......if the predriver heatsinks are round flying saucer looking the upgrade was done in the past.....if not it needs to be done.
There are in between things that are now constantly cropping up on theses 50 year old amps.
The axial caps on the driver and input boards are regularly wonky......I just replace them.
As mentioned earlier these amp's have so much reserve they will often pay just fine with 2,3, or more individual output transistor open, whether they have failed of the .33 or .56 wirewound has gone open...only a bench stress test will show it.
There are more things that a proper test bench test could show but the first two things you can try yourself by swapping speaker wires, speakers and amp duties.
Oh and stock up on the NSAIDs, people forget how heavy these amps are.......
