MC275 Mk. VI with Raytheon 6414 tubes?
Lockheed Mar
The 12AT7 tubes on my MC275 Mk. VI are old and need to replace. Could I use these Raytheon 6414 tubes on 12AT7 spot.
Thank you.
Thank you very much, Ron. I should sell them and buy some 12AT7. Could you advise me some good NOS 12AT7, my power tubes are KT88-Z.
Thanks.
They can't be that old if they are factory, the small signal tubes last a very very long time. It's the KT88's that get to the point of needing replacement a lot sooner. If you want to change tube for the sake of seeing if you get another sound quality that's one thing.
I suggest NOS Mullard CV4024 / 12AT7. They can be had for not much more than new issues. Very pleasant sound and will last for a very long time. They do that sexy flash on startup, but the effect is largely lost in the mkVI due to the startup LEDs.
How is the sound of these tube when it come to bass? and also the detail of mid's and hi's. I want to try it on my 300b amp.
How do I know if they are the original NOS?
Any takes?
index.php
Any takes?
index.php
As they are relatively inexpensive, your best bet is to buy a pair and listen for yourself. As you know, tube sound is circuit dependent. But they are good tubes, well balanced, with slightly more clarity and detail than the stock McIntosh/JJs. As for being genuine, buy them from a reputable dealer, such as tubedepot.com or upscaleaudio.com. If they look like the one in the picture above, you are all set. They are relatively inexpensive and plentiful and I don't think the fakers have so far bothered with this tube. There are other much more profitable tubes to fake...
Even better is the Mullard M8162.It is an 12at7.Worth checking out.They are what I use as well as the CV4024.
