First thing that comes to mind: if it has not been done already and recently, the MC 30s need to be electrically restored. These or 50 to 60 years old and so may not be running at the correct performance level because of worn or failed internal components. Were they mine, I'd have them recapped and have all other components checked or replaced as needed. Also contacts and controls need to be cleaned and tubes tested. The amps should then be bench tested to prove they're meeting factory spec. Hopefully yours or restored, but if not, that would be the first order of business.
My experience with Mc preamps (I own 4 that span about 50 years) is that, while they do sound somewhat different, I like the sound of all of them. Given that, you're decision on which Mc preamp to get depends to a large extent on what features you want. Do you want the vintage look and all-tube sound? if so, you need a C11, C20, original C22 or even a C8/C8S. These preamps are all 50-ish or more years old and will need to be completely restored and will require on-going maintenance (mostly occasional cleaning of controls and contacts.)
Note that some of the SS models from the early '70s have issues with the volume controls that seems unfixable. Ask in this forum before buying.
More modern preamps have measurably less noise, improved performance and require less maintenance. If you're a tube-purist, note that most of the more modern Mc tube preamps are hybrid SS/tube preamps with the C2200 being the most purely tube modern preamp. But in my opinion, being a tube purist is not required with Mc preamps if your goal is great sound.
So do you want modern, in-between, or vintage? Tubes or SS? And what features do you want?
McIntosh have made a lot of great preamps since the '50s and I recommend that you start shopping here where they're all listed and described:
http://www.mcintoshcompendium.com/mp-pre-amplifiers.htm
If you narrow down your search to a few specific models, you can check back on this forum to get more model-specific advice from the forum members here.
