Yet another 1900 with a horrible tracking volume control. Output on the right channel starts out fairly close to the left down low, but gets to around 50% off by 1/2 volume. Looks like I will be using just the amp section in this hooked to an outboard preamp until a suitable replacement control is available.![]()
It's original, and by reading very common to have this issue over time. That seller has banned me from buying, and blocked me from messaging. I'd pay him a visit if I was to ever end up in his location.I wonder if it’s original or if it is one of the notoriously awful ones from that ebay seller. Have you had it opened to see if it looks replaced?
I thought I read where that was tried in this thread and not successful.Has anyone tried Mark Opat?
He’s got all kinds of old , vintage pots and switches. Worth a shot.
Old Radio Parts - Contact Me
oldradioparts.net
I'd settle for not perfect, but the nearly 50% difference at certain positions now is far from acceptable, it's real bad. But one thing is interesting, this old girls amp and preamp sections still perform extremely good when run on test equipment, both channels very equal having 100% original components. But once the signal comes out of the volume control, it's way off.The seller hifistereo/hifistereorocks/captainfantastic is the seller that I meant, his quality and his “return policy” has been the subject of several threads here, sells pots that he claims work, ...
That is a tough position to be in, several ways to go with that pot but nobody has found a perfect replacement yet. McIntosh Parts and Audio Classics have both sold or rebuilt these, but even at their prices it has been reported that they don’t track perfectly.
Being that far off though, I was expecting you to tell me that the PO had replace it, likely with an ebay quality part from the above notorious seller.
Well, I'm more interested in keeping things 100% like it should be, meaning functioning correctly as it should. If anything I will run a separate preamp and just use the amp section for now since it has main in / pre out jacks. If it didn't have the on / off switch included on the control, one could replace it with a high quality volume control separate of the on / off switch.How about taking tape out to a passive volume control to amp in? You’d lose balance and tone controls, but still be able to use the tuner, phono stage, and other inputs
Just need to ground the shield to the chassis. They have it grounded to the pot itself.I see no reason why not if you’re turning it on with an external power strip or similar, just like leaving the switch on.
Here’s a photo off the internet. 500k Balance pot is dual gang wired opposite one another. Lug 1 is the green wire from the audio in, Lug 2 is the 0.22 capacitor, Lug 3 is ground connected to three wires and bridged across to Lug 1 of the other gang. One of the three black wires is loose. Not sure where it goes. There is also a black wire sitting at the bottom of the chassis. It’s grounded wire. Don’t know where that goes. Do they go on each of Lug 3 on the volume pot?Just need to ground the shield to the chassis. They have it grounded to the pot itself.
