No real history on the EQ101, a transistor or two and a power supply filter, only had 2 on the bench in 3 years.
Either figure out the wiring, ohm the leads, and wire them back, or order a new one from the factory. You would be surprised what they still have in stock, I just ordered a 162-031 19K coil for a MR73, retail at $6, better than telling the customer his tuner is scrap.
Ahha yes, the sign of a learning technician, make do with what is available, check the pin out of the new can, the numbering and layout is a bit confusing.
There was a discussion some time back regarding MX-110s and I/F cans with where they were rebuilt to eliminate a small silver-coated cap in the can's bottom. Might search with those elements.....I've got an MX-110 with the symptoms that will need attention at some point.
Cheers,
David
