MC 2100 hisses in the right channel
Ok, it is an MC 2100 that I have been helped with by Terry already as to cap replacement. Thanks Terry, the Nichikon caps worked out great.
I am ready to begin looking for the source of a right channel hiss.
So to understand, I need to disconnect my RCA preamp inputs and see if the hiss goes up and down with the gain controls to isolate C 32preamp/other inputs from amp issues? I just read the C 32 ribbon cable post a bit ago.
With everything connected I already note the hiss does goes up and down with the right gain control. It's just enough "there" to note at no preamp volume, and warn me it is time to find the issue.
I think tomorrow I will disconnect the turntable, tuner, and CD from the preamp and see if it is an input.
If I am directed to disconnect the preamp from the amp, I think I will connect the garage speakers rather than the Cornwalls for that test.
Presuming I am only concerning myself with the amp, after a no preamp no input gain knob turn and listen gets me the hiss, where to start?
The amp runs cool. I never did put the screws back in for the cage after the cap replacement. I have slid the amp out, removed the cage, and placed my hand on the sinks after 30 -45 minutes of play time. The sinks are quite comfortable to the touch.
The amp hisses more noticeably at start up than after playing a while, I think (maybe).
There was no hiss after the cap replacement, this hiss just sort of "came on" a bit later.
So:
Should I disconnect power and begin checking across resistors with my ohm meter for rated resistance versus actual?
Is the "freeze" spray I have heard about valid? Play, spray, ( pray
)and listen for increase in noise? Didn't see one suggestion to freeze spray in this entire thread, so the lack of that suggestion makes me suspicious.
Well, I wanted to jump in so I will get notification of replies, and begin this. I am on vacation for the next ten days, so I wanted to get this done, among other things.
Thanks Jeff R
Ah yes, and if I do find out of tolerance resistors, source from the McIntosh factory, or from whom should ? purchase new resistors?
