Need help with Mac 1700 MPX problem
Hi,
I'm loosing my hair trying to restore MPX operation on this 1700. The 6EA8 tube was very weak on both sections and was replaced with a NOS. Also swapped the 12AU7. IF and RF tubes check fine. IF alignment in accordance with manual went fine, as did RF. The problem persists: there's no response from the 19khz transformer or phase coil- the manual refers to "...max negative DC at pin 7 of V8", but there is no DC present at this point; regardless. The 19khz transformer checks fine for continuity, as do voltages in the circuit. I pulled V7 and adjusted 38khz. at pin 6 of V8. I can see 19khz pilot at TP1, but not on T6-- should it not be present on pin 6 of V7?? I suspect an undetected bad ceramic cap but have not been able to get any closer- the caps check OK as do diodes and resistors.
Any help appreciated.
Thanks, Cornell
Hi,
Thanks, Cornell
