Hooray!
Spent about 4 hours last night replacing capacitors and then can capacitors. I originally planned to re-stuff them but decided against it and got new can caps from CE manufacturing:
40-40-40 replaced with this:
https://www.tubesandmore.com/products/capacitor-ce-mfg-525v-404040uf
50-50-50-50 replaced with this:
https://www.tubesandmore.com/products/capacitor-ce-mfg-350v-50505050uf
60-40 replaced with this:
https://www.tubesandmore.com/products/capacitor-ce-mfg-60-f525v-40525-10450-2550 (and ignored the 10 and 25 sections)
All the other parts I got at mouser.
I did all the work on this myself, but had the guidance of the owner of
Rain City Audio in Seattle WA. I would highly recommend him for any work you have. I did the work at his workshop with his tools.
First shot of the underside before touching the capacitors
The first capacitors to go. (See end photo for replacement)
Next in line
The new capacitors are so much smaller!
This one was somewhat hard to access, it's in the FM section
2 each on each of these parallel boards that needed replacement.
The new ones installed
Looking similar which I am rather proud of!
The first Can Capacitor to go, the 60-40. I took this photo for reference and then also wrote down that the single red wire went to the 60uf and the orange wires went to the 40uF, the Black wires are ground, obviously.
New Can capacitor installed. I oriented it slightly different, but it is correctly wired.
Photos of the 40-40-40 uf Can Capacitor before replacement.
Photos of the 50-50-50-50uf Can Capacitor before replacement
An After shot of the replacement capacitors. You should be able to make out 6 on this if you look close.
Old vs New Can Capacitor. If you look at the old one you see a bit of a bulge near the etching. Not sure if this is due to failure or if this was normal due to the etching?
All the parts I replaced (missing one black capacitor which fell of the table and I found later). Notice the bulges in the cans? I assume this is due to them leaking but I'd be curious if anyone has knowledge of if this is normal due to the etching process.
Fired it all up and re-biased the tubes and it works well and is sounding good. Now to go give it a long listening test.
