With the CE can tie the 30 and 40 together, less ripple, more power, and less distortion.
I did pretty much the exact same thing with one of my MC40s, and I CAN compare it to the old one (by putting my preamp in "mono" mode so each MC40 gets the same signal, and rotating the balance knob to one side and the other) and the bass is much improved (presumably due to the 820uF snap-in type voltage doubler caps and 100uF bias supply cap with smaller shunt).Now I did a complete rebuild...every solder joint, resistor and cap was replaced. For the caps I used a mixture of Russian PIO caps and polypropylenes. Jim McShane made the suggestions. Well with one done, I can say it sounds fantastic. Can't compare to the original as both were dead when I got them.
Generally, with power supply filtering, the bigger the value the better - to a limit, because very large values can increase the peak currents on the power transformer windings. This can be mitigated with special types of diodes (soft recovery, etc). This is getting beyond my knowledge level though, so I defer to recognized experts such as Terry Dewick and Jim McShane. As a general rule of thumb, I'd say use values that are at least as large as the original, but not more than double unless you have a deeper understanding (than you or me).Not sure I understand. If it isn't critical then why use different values originally?
True, because MC40/240 have solid-state rectification (i.e. diodes) whereas the MC30 has rectifier tube. But many of the principles are the same.Your 240 is a different animal than the mc30 so I'm still not clear on what values to make.
