CruzBay
Yes. This change occurred in early 2Y s/n units. I used to add the circuit to all my 1Y amps. My MC2300 fans cycle a bit under normal use as both amps are rack mounted. I've never been able to kick on the fans on the 2500s or 2600s though!
I suppose it was inevitable they'd do this. BTW I never actually had an MC-2300 on the bench myself (nor actually seen many in the wild) but '2500's and a few '2600's came through.
I wonder if it'd make sense (more for curiosity) to use 2 different temperature switches giving each fan its' own threshold of operation. I can see you'd lose flow through the 'late' fan in reverse. Or make a PWM motor controller work off a voltage ramp.
I was going to ask what diameter, and realized I have 2 downstairs to look at. OK, holes are 4 inches apart, fan is likely 4 1/2 or 5 inches across. What voltage?
Wait, I'll never know I have a bad fan....The good ones don't run either.
