Ed in SoDak
RadioHead
Hi Redboy,
Looks nice, hope you can sort out the hum! In the closeup underside view, I noticed two unsoldered connections. It was probably an in-progress pic, but might be something to look for?
Since you're using a three-wire plug, how are the other two wires connected? The white wire in the AC cord is supposed to be neutral, and black is the hot. The white wire should connect to circuit's ground. The green ground wire should go to the chassis. A 47k resistor and a MOV would connect circuit ground to chassis. Might be easiest to simply disconnect the green wire as suggested and make sure the circuit's "ground" side goes to the white wire.
A DMM set to AC could be used to make sure there's no "hot" voltage on the chassis by metering from there to the ground at your outlet.
I've had amp hum caused by a bad tube. Might not hurt to swap other tubes in if you have spares.
-Ed
-Ed
