Thanks for the reply, Conrad.Never seen one, but if you can measure the wire with micrometers it should be possible to buy more. Maybe from Goodfellow- http://www.goodfellow.com/E/Tungsten-Wire.html
I found some fine copper wire and connected it up.Why in the world would it have had to be tungsten? BTW, there are probably cheaper places than Goodfellow.
Sorry to hear about the wire. I have a MA 505 an worry about that.
Try doing a search on "corona copier wire tungsten". Fairly common part for copiers.
I bet that stuff would work, you know of any supplier of miniature wire terminals
I bet that stuff would work, you know of any supplier of miniature wire terminals![]()
My camera doesn't zoom in that closeNeed a close up picture or two.![]()
This very nice one popped up on the net and saved by bacon.I'm assuming that you found the service manual on vinylengine that describes replacing the wire.
However, here's some guys DD-7(DD-40)
http://www.micro-seiki.nl/database/DD-40 Service Manual.pdf
I'm sure this manual will help me to dial this table in to a much better degree as well as I hope I can figure out how to get the tonearm lift to function better.
The lift doesn't provide enough lift.What's wrong with the lift? I had one of these tables awhile back ... I had to fabricate a new lift cause it basically separated at the screw head that holds the crescent shaped arm rest to the lifter rod
Perhaps a damping fluid issue or the lift height needs to be adjusted?
Something like this for the hook onto spring load.
Same thing for the front, sans the "hoop", just something to crimp on the other end of the wire to provide the tracking force set screw some bite.
We are talking tiny![]()
