ThanksSoundsAlike, I bet one of these procedures works.The arm has a few ways to adjust the height of the lift. One thing you got to mindful of is the dimensions of your cartridge/head shell... When I owned this table I noticed that switching head shells and cartridges would force me to mess with the tonearm lift height -- once you get it working though I doubt you'll have to mess with the heights any more.
There's a tiny screw on the tonearm wand, if memory serves me correct. The screw on the wand goes all the way through the wand and should be covered in a rubber material (it tends to disintegrate over time so it may just be bare metal) -- that's the part that actually his the crescent shaped tonearm lift paddle. I believe you can adjust the tonearm lift position this way.
OR -- you can move the tonearm lifter rod up and down slightly. This is a horizontally orientated screw near the tonearm lift mechanism.
OR -- you can adjust the tonearm height via the allen wrench port near the base of the tonearm assembly.
Hope this helps.
