gorillasalad
It's really simple. Two steps.
Step one: Mid-fi
Mid-fi - When you stop hearing the resonation of your equipment and the music is floating in the air. When cymbal hits or S/P/F vocal sounds don't resonate your speaker and bring you back to reality. That's what I call the 3D stage, your record is floating in the air. Since I only build hi-fi setups for vinyl, I'll stick to that here. You have your stylus and cartridge perfectly configured, sibilance is null and the sound flows into your system in a liquid state. Mid-fi is absolutely hi-fi in the original sense. You've reached "mid-fi" when you stop hearing your equipment and start hearing the recording floating before you in incredible detail. That moment when you realize that all of the records in your collection have a whole lot more detail and nuances than you ever knew.
Step two: Hi-fi
Hi-fi - Not really such a massive step, this is the realm of perfectionists. And many would correctly argue is a matter of signal processing. A 10,000 dollar amplifier is also a signal processor, it does something very unique. It creates a "space" for your music. Now even when you listen to a crappy recording, this hi-fi amplifier will powerfully and masterfully create an auditory soundstage for it. It will sound really good. All of the details of the recording will be there in proper balance and it will sound unbelievably clear, even if the recording isn't. For me, these systems are essentially signal processors, the best of the best, and they create a soundstage even if the record you are listening to doesn't really have one.
Issues and conclusion: A very good "mid-fi" system is what it should be, a signal amplifier. If the record you are listening to was produced amazingly, and the pressing is impeccable, you will be in absolute nirvana. A mid-fi system produces an honest sound and a realistic one, probably very close or exactly like the band heard in the studio. A hi-fi system has its own soundstage, can create its own headroom, it's like an electronic cathedral in a box. No matter what recording you are playing, it will be both accurate and at the same time recreated in the fancy tube stages and such.
Step one: Mid-fi
Step two: Hi-fi
