lolwtfbbq
I think I figured out how to fit everything in the Optimus Pro x44av.
I mocked up the layout:
With this configuration the crossover fits perfectly on the top of the cabinet.
The big coil will go on the back of the cabinet perpendicular to the rest of the components, (note the coil layout.) Same orientation, just 90deg off axis from the other coil.
I have 2 more questions though;
How hot do those resistors get? I mean I know they can dissipate up to 10w before they begin to fail, but wouldn't the drivers blow before the resistors see that much power? I'm wondering if I can mount them on a plastic surface that will velcro to the top or if they should just be epoxied to the cabinet.
The other question is if the small inductor will affect the tweeter being so close to it. The tweeter magnet won't affect the coil, I know. But will the ferrous material in the tweeter significantly affect the inductance of the .4mh coil? I'm assuming if it does then it's negligible because it looks like in most of the builds in this thread, the crossovers coils go right behind unshielded woofers and that doesn't seem to be an issue.
