One case that I recall vividly involved an FM tuner connected directly to a cable TV system, which had the cable shield tied to an earth ground at the point of entry into the building.Thanks. I guess I cant picture equipment in one cabinet being connected to power outlets that could be connected to different circuit breakers or grounds. I'll check the noise level with and without them in the circuit.. Thanks for your response.
It is unfortunate that you have not been able to find good NOS 12ax7. I have found that even used OS ax7 and ecc83 are better in some of my vintage amps and integrateds than the new tube offerings. Like other "auction" buys you need to deal with trusted sellers that have a proven history. Then if you have an issue there is not a problem with resolving it.Thanks for the response. I have had so much bad luck with NOS that I wont go that route anymore
I have been led to believe that it limits ground loop current flow, which could reach pretty high levels if multiple earth-grounded components are connected to the preamp -- when those earth grounds are separated from one another.
Try with the case on. It sometimes makes a significant difference in the noise in a PAS.
Also, try swapping tubes- one or more of them may be abnormally noisy.
Is it 500uv of noise on BOTH channels, or is one noisier than the other? If it's both, it's likely power supply (caps?) or radiated noise (possibly from having the lid off, at least in part). If it's only one channel, it's likely a tube or a coupling cap, or a bad connection somewhere.
Ahhh- I re-read the Dynaco manual, and I see the misunderstanding. It's 2uv "Equivalent" - referring to a noise level at the output, equivalent to the preamp output at 2uv of phono input level. That would be 2uv compared to the PHONO INPUT level (NOT the output level)- which in this case, is 13mv. That calculates out to about 76dB. That's still a pretty lofty goal for a vintage piece, but believable. Yours, at 65db, is noisier, but not UNBELIEVABLY noisier. And that 10dB of noise (or so) could definitely be caused by stuff like noisy tubes or having the lid off.
Regards,
Gordon.
My preferred fix for this problem in PAS chassis is a built-in diamond buffer IC running open-loop and powered from the existing +/-11 VDC heater supply rails. For example, the BUF634 is still available in a conventional PDIP-8 package at this time: https://www.digikey.com/product-detail/en/texas-instruments/BUF634P/BUF634P-ND/251038A new wrinkle. This PAS2 does not like driving a transistor power amp.
Thanks Mike.
Gordon I dont understand your point. Being a cathode follower if it comes on with the PAS2 (switched outlets) there wont be any voltage at the cathode till the tube warms up and it will be a gradual rise. THere will be a large cap isolating each output..probably..I havent done the numbers yet..somewhere around 1.0 ufd or more but it will also get charged gradually.Clearly I missed something somewhere.
Your observation are great. I still cant picture how that 15 Volts would get to the cathode that fast and if it appears as the tube warms up it will be a gradual rise. The SS Amp is a Yamaha RXA1050 cap coupled inputs so as long as its a slow rise there shouldnt be any protection problem. Yes, if it were DC coupled and that 15 volts appeared it would probably end the speakers life since I am not sure any protection circuit would recognize that as a fault. It will be interesting when I test it on the old Technics I use on the bench..With a 2.7uf cap on the output of the cathode follower, I have noted transient DC voltage of up to 15V for a second or two, with a "normal" solid-state amp impedance (about 40K) connected to the output of the preamp. Positive on startup, negative on shutdown.
That's no big deal if your driving a tube amp (because the tubes in the amp won't come up any faster than the tubes in the preamp)- but a SS amp (which comes on virtually instantly) will have issues, naturally. It makes my JVC bench test amp go into protect momentarily, if I don't wait about 15 seconds after turning on the preamp, before turning on the amp.
Regards,
Gordon.
The logic is to provide a flat frequency response into a low impedence solid state input from a high impedence tube amp down to between 10 and 20 Hz while still having enough voltage to drive the amplifier to full output. You might want to check the size of the coupling caps in any discrete bipolar transistor amplifier.There seems to be very little logic using a 2.7uF output cap. It's not a battery charger it's a preamp !
Thanks Max, all great ideas but a PAS2 preamp is great for freq response, noise, etc but it unfortunately, due to the lack of amy amplification after the tone controls, it doesnt have any gain to spare. I'm doing only the standard mods on the PAS2 such as removing the selenium rect and 12X4, replacing defective caps, and replacing the jack strips which are so worn they wont hold a standard RCA plug. When I get this tube ensemble finished I'll provide pictures..If I can figure out how to do it here.For a "quick fix", try putting a 0.25W 100k ohm 1% ohm resistor in series with the output, preferably right at the input to the power amp. This will form a voltage divided with the input resistor of the power amp, loading the preamp correctly at the expense of some gain.
If you put the resistor inside the RCA connector of your interconnect you can avoid modifying the amplifiers.
Usually old preamps have too much gain anyway, so this could be a viable solution, eapecially for occasional use, and is totally non invasive and almost free.
As for the transient issue during warm-up, just turn the preamplifier on a minute earlier than the power amplifier and this way the power amplifier Will never seeThe DC voltage
I don't think you need the corner frequency to be 1.8 hz. A 0.22 uF cap is more reasonable.The logic is to provide a flat frequency response into a low impedence solid state input from a high impedence tube amp down to between 10 and 20 Hz while still having enough voltage to drive the amplifier to full output. You might want to check the size of the coupling caps in any discrete bipolar transistor amplifier.
