I have a Mits DP-EC8. It has been packed away for over twenty years. I recently pull it out and there is one problem, when I press start the tonearm will raise from the rest stop and the arm will proceed to swing over the disc. The problem is it continues to swing over the disc, never lowering on to the disc, then it returns to the rest position. When I stored it away it did not have this problem. If it turns out it needs parts I will probably part with it, no pun intended.
thanks for the help
john
thanks for the help
john
