Wigwam Jones
Caesar non supra grammati
I have a 1994 Mitsubishi Mirage with a 1.5 L four in it, mated to a 3-speed automatic transaxle. I bought it cheap on eBay and it's done well. But it needs a set of front brakes, and they're well gone, so new calipers, rotors and pads are required. Looking at $450 or so.
Deciding whether to go ahead and get it done (car has 114K miles on it) or consider it having given its all and moving on to another used car.
Engine is running fine, but going through about a quart of oil every 3,000 miles.
I was thinking that if I sink the money into the brakes, I might as well consider the car a keeper for awhile longer and start saving up for a motor in the next year or so.
The engine is the Mitsubishi base 1.5-liter 4G15 engine rated at 69 kW (92 hp). However the next level up sedans (I have the base model S), the ES and LS sedans came with a 1.8-liter 4G93 engine rated at 84 kW (113 hp).
I understand it's an easy swap. Just considering options here. Would be nice to get a bit more grunt getting on and off the highway; the car will barely do 70 MPH, and with the AC on, accelerating from a dead stop is kind of like a sad go-cart.
What do you mechanical types think?
