Thanks guys. I appreciate all the advice. However, I wasn't asking about brakes. I can get the brakes fixed. My question was about engine swapping. And really, not to be obtuse, but all I've heard is "don't do it," or "your engine should last a lot longer."
So, yes, I get that my engine should last a lot longer. You have put my mind at ease with regard to the oil consumption. However, wasn't really thinking to replace the engine because it was going to die, but because it doesn't really have enough power to suit me at times. I'm not looking to build a tuner or a race car, but a bit more oomph would be appreciated. That was the basis for the question.
And with regard to the "don't do it" statements, again, I certainly do appreciate the comments, but I've also asked "WHY NOT" and no one has answered.
Wrt engine swaps, here's why I would shy away (and I've done plenty).
1) If you buy a junkyard motor, you don't know the real condition. Ideally you'd want to run a compression test, a leakdown test, etc.
2) Even with a 'known good' motor, you still probably want to do a few things like front and rear seals, etc.
3) You can buy a running car, so you can verify that the motor is running before you install it in your car, but now you have to pay your mechanic to yank that motor too.
4) The motor is bigger than what you have - is your 1.5 liter radiator up to par for the larger displacement motor? What about the rest of the car?
Unless you have the means to do all this yourself, it's almost always better to just sell your car and buy the car that has the motor you want. The only time this kind of thing works out well is when you have a friend that has the motor you want in his car, you know it runs well and has been maintained, and somebody rear ends him.
A) What's your current car worth?
B) What would a junkyard motor cost you, plus some pre-installation maintenance (timing belt, front and rear seals, etc), plus installation?
C) What would a known good motor cost you, plus installation?
D) What would the car you want with the 1.8 liter motor cost you?
If you are paying somebody else to do the work, then 90% of the time D-A will always be less than B or C.
hth,
bs
