HiFiAaron
Member
Hello everyone,
I am recapping my first set of speakers, a pair of Mitsubishi diatone ms-20's, and was hoping i could get a little advice. What type of capacitors should i get? Mitsubishi used Rubycon Nonpolar Axial Electrolytic Aluminum Capacitors originally that are 13mmX31mm in the 15uF rating. I notice that most electrolytic capacitors with the same rating are smaller. Would standard electrolytic capacitors sound good? Is there any use in changing the inductor coils? If so how do i know what gauge wire to get? my guess is that the lower number on them is the mH rating correct? Also is their any need to replace the resistors? If so what type should I buy?
Any help would be greatly appreciated, thanks in advance.
![IMG_0882[1].JPG IMG_0882[1].JPG](/forums/data/attachments/795/795696-46cce35b88f88a2a5395ef3b62084597.jpg?hash=RszjW4j4ii)
