MM Phono input vs. MC Phono input
You have a LOMC cart at .3mv
You use a phone stage for LOMC with a 15x gain in voltage
Your signal is now 4.5mv which is decent for line level input
No stress on the phono stage or the amp
Now try the same with a MM cart that STARTS at 3.0mv
Your signal is now 45mv (versus 4.5)
You risk damage to the following:
The phono stage is probably not made to accept a signal above 1.0mv so you risk damage there feeding it 3.0mv
if the phono stage survives, you are pushing a huge gain at the amp - 10 times what it should be
You'll also be pushing extreme noise
Does this help ?
Thanks Rob,
I understand what you are saying and the concept of overloading. The ol' proverbial 10 pounds into a 5 pound sac... I was trying to put my finger on if anything could be harmed using the high output cartridge into a low input - you summed that up well and the answer is yes it will.
Some how I had it in my head that the volume control would help me here. I knew the higher gain would be present - just I wasn't sure if it would cause damage other than distortion.
Thanks again for helping me beat it into my head!
Look up the prescribed loading on vinyl engine. I'm sure you are within the prescribed tolerances but they list resistance loading specs for almost every cart and yes it makes a big difference with MC carts.
This is why I like my B&K MC101 so much. It has sockets for changing out the resistors and the range for MC carts can be huge.
Enjoy
Eric
