No change still reads 129V
I measure -56v with muting on and tuning dial turned so that the lamp shines bright.
With mute off I read -1v
In my 18 the mute function has become really weak. The sound is lower when it mutes but I can always hear some interstation noise. How is yours?
I suspect that this is the root cause of the pop...
I am reading a bit more about the photocells now... I am thinking that they may not wear out.. It's the neon tube. This is actually good because the hard part to spec would be the resistive element, it's on and off resistance value.
Can LEDs be substituted for neon to implement a more lasting fix?
Would it just need a resistor of higher value? And are the resistors for the neon lamps built in to the LDR modules or outside of it?It may be possible however it would require additional components because the voltage to drive the LED is much lower.
