It's more complicated because you have to consider the other parts of the circuit that might be impacted. You might be able to do it on a small circuit board with surface mount parts and still fit in the same space. The problem is that the original circuit is slow. If you replace it with really fast parts then it might not eliminate the pop.
It looks like the resistor for the neon lamp is provided externally.
I think the easy thing to do would be to simply try replacing the part with a cell and lamp that are shrink tubed together. I have a bread board that I can wire up to the 18, then I can just sub parts till I find a combo that works.
