monkboughtlunch
Riddle me this: Is it normal for the visible NE2 muting neon lamp indicator in the left rear of the unit to momentarily light up when the selector knob is turned to FM (even when the "Muting Off" switch is depressed and the receiver is tuned to a strong signal)?
bktheking and hirscwi, does the visible mute lamp on your non-popping units flicker on momentarily when you first turn the knob to FM?
txturbo and fhamre, does the visible mute lamp on your popping units flicker on momentarily when you first turn the knob to FM?
My popping unit does flicker on for a moment and this coincides in lock-step with the popping noise. I wonder if there is a relationship (e.g. a resistor that's connected to that visible NE2 lamp out of spec etc).
