Monolith on Sale
Oside
Last night, I made my first intro post and mentioned I was looking at subs to go to 2.1. I had it narrowed down to a few of the 'bang for the buck' models, but one went on sale today and I went for it. Thought I'd share if anyone is interested. The Monoprice Monolith 12" THX Certified is on sale on Amazon for $634.30. This sub competes with the likes of SVS SB-2000, Rythmik, Outlaw & Hsu 12 inchers and it is a significant price drop.
I’ve never heard of it before didn’t know mono price made high end subs . If you think it’s worth it go ahead , I build my diy sub for around that price or cheaper. But sounds epic !!! So it’s one of best subs ? Mono price? What’s it look like got pics or specs?
I thought about DIY, but I never have the patience for doing the finish on electronics - once it works, I want to use it! Not so good for living room use.
Yes, Monoprice has blown reviewers away by stepping in to the HiFi marketplace with a few select products. It's an impressive sub (even for Martin-Logan fans). It beats all of the subs I named above. Specs: https://www.monoprice.com/product?p_id=24457 Comprehensive review with test results: https://www.audioholics.com/subwoofer-reviews/monolith-10201d-12
Also interesting is their pure tube amp: https://www.monoprice.com/product?p_id=27222
Edit to add some specs for those who don't want to click:
Model 24457
Woofer 12" cone
Cone Material 2 layer long fiber pulp/glass fiber cone
Voice Coil 60mm with high temperature aluminum wire and black anodized aluminum bobbin
Surround FEA optimized NBR (nitrile budadiene rubber)
Motor FEA optimized, 2 aluminum shorting rings, undercut T-pole focused field
Magnet Ceramic Y35, 2 pcs total 144 oz.
Xmax 18mm (one-way)
Xmech 80mm (peak-to-peak)
Enclosure Sealed or vented HDF cabinet with horizontal and vertical bracing
Finish Black Ash
Amplifier Class D 500Wrms / 900W Peak Power
Frequency Response (-6dB) Sealed Vented (1 port) Vented (2 ports)
Extended EQ 26-200Hz 19-200Hz 18-200Hz
THX EQ 29-200Hz 23-200Hz 20-200Hz
Harmonic Distortion <1% 20-100Hz (90dB @ 1m)
Variable Level Control +15/-20dB
Crossover Inline/Bypass variable 40-160Hz
Inputs RCA (2), XLR
Outputs XLR
Signal Turn On Selectable always on/auto
Auto Turn Off 30 minutes
Dimensions (H x W x D) 22.8" x 16.7" x 23.6" (580 x 425 x 600mm)
Net Weight 98.5 lbs. (44.7 kg)
Gross Weight 125.7 lbs. (57 kg)
Model 24457
Woofer 12" cone
Xmax 18mm (one-way)
Finish Black Ash
Inputs RCA (2), XLR
Outputs XLR
Woah a 12 comparable to my 15” same rms how can xmech be so high if xmax is 18mm?
Sounds like a beast my sub is sealed tho , vented has more bass at tuning point and higher spl .
My old si ht 15” I got a thread on it, has 25mm xmax or so and forgot xmech around 50mm.
This mono price sounds just as good or better, my finish was nicer but got damaged moving it to a friends house my dad forced me to move it then 6months later I brought it back. It damaged one of my towers actually had to fix the leg .
I’d say go for it !!! What’s new price ?2k?
Sounds like a beast of a 12” model !
I was initially looking at sealed subs because my primary use is music (though, I'll be cranking the movies now), but this one was also in the running because of performance per dollar. It has the "plug the holes" version of sealed - if you read the review link, you can see how it tested with both ports open, one closed, and both closed. I imagine I'll be using it with both ports plugged - but we'll see. A friend of mine has one - so I've heard it and it is amazing - he is more of a home theater user, though.
I’d say go for it !!! What’s new price ?2k?!
Nope $634.34! - that's why I jumped on it and bought it yesterday. They actually make a 15" model with an amp twice as big that goes for $1300
The 15” looks like a generic spinoff of the pb ultra? https://www.svsound.com/products/pb16-ultra
Look similar designs. Can get two monoprice for one tho .
What’s thx certifying do?
Can’t some diy do thx just no one pays to certify one .
I don’t understand there prices wouldn’t two 12” for 1600 be more value then a 15” for $1300.
Wish you could buy two 15” at a discounted rate.
Yeah, I was debating between the Mono and SVS, then he sale made the decision for me.
You're right there is no magic in THX, seems to be just performance standards-but they do the certification, so it has some guarantee of real-world performance, rather than just adspeak. Some on THX in this review: https://www.audioholics.com/subwoofer-reviews/monolith-10201d-12
