The cartridge that comes with the Monolith is unmarked. Nothing on it anywhere that identifies it as being made by Audio-Technica, except the sound, which is identical to the other AT100 variants I have. I suspect that was part of the deal that kept the price low.
And yes, for $180 its a great buy.
Here's my last reply from Elac concerning the the Monolith and Miracord 50 being the same:
Sorry for the late reply…
I know they look similar, however, they are different…
1. The Model 50 has a damped platter. The underside of the platter is covered with strategically-placed elastomer damping material. Not only does this material drastically reduce the platter resonance (the RING when the platter is tapped) but due to the increased mass, it also increases rotational inertia, improving speed accuracy. An undamped platter will ring like a bell, and that resonant energy is transferred through the vinyl back to the phono cartridge resulting in distortion.
2. The Model 50 incorporates servo speed control. A sensor and motor control circuit measures the actual platter speed at the bearing and corrects it instantaneously in a closed-loop feedback system. This technique improves the Model 50 wow and flutter specification by over 50% and speed accuracy by 66% over the simple belt drive and DC motor. (Our Wow & Flutter is 0.15 vs. Monoprice without servo at 0.25). ** Actually the Monolith is .2 not .25
3. The motor servo sensor for the speed feedback is integrated into an improved main bearing assembly. The platter rests on this bearing, so it takes not only the vertical load of the platter mass plus the record, but it also has to resist the torque applied to it via the drive belt and motor pulling laterally against it. A better bearing has lower friction and lower rumble, in this case by 10% (motor speed variation of the Miracord 50 is +/- 1% vs. Monoprice +3/-2 %)
4. No separate ground on the Monoprice table.
We will update our website with these specs….
Hope this helps….
Addendum: Rubber under the platter? Using the rubber mat does the same thing. The servo motor is the same for both. The Monolith is internally grounded to the blue wire, much like Rega does. Nothing he said shows $250 difference.
