Moreplay Preamp by Bottlehead.
Andre Garcia
“WITHOUT MUSIC, LIFE WOULD BE A MISTAKE”
Hi to all.
Little late for the party but...
I finished my moreplay valve preamp.
This is a fun kit to assemble, the dimensions are compact you dont need too much place, the instructions are straight forward with no room for mistake. All tests passed flawless. The valves are Russians 6v6.
Moreplay can run easily those two MC7100 in mono configuration. Image, clarity and base is just top notch.
I am very happy with Bottlehead quality.
Did they make the top plate thicker? I have an old Foreplay and the top plate is thin enough that it bends when plugging in tubes.
Be sure that the amps don't overheat. The way they are stacked in the photo, getting adequate cooling air flow could be a problem.
Thanks for your advice.
McIntosh Amp run cold as cucumbers. The NAD I have is an oven with a light load.
Andre.
They appear to be old school class AB. 100w/ch into 8ohms.
jeff
Hi, Jeff.
It is 100 W/CH @ 8 ohms or 300 W mono. people dislike this model because doesn't have autotransformer. the sound and quality is after all a Mcintosh.
AG.
I don't have a real sequence but here are some pictures taken during the assembly.
Parts received.
Custom pilot light.
Wood Frame gluing. I used a granite surface to ensue flatness.
Chassis and transformer bell painting.
Wood frame treated and mechanical component installed.
AG.
