Motor sounds...
And because you absolutely cannot have too much Detroit 2-stroke sound:
As one of the comments said: "...never heard a vehicle that's so slow, sound so fast...
Regards,
Gordon.
The sound of a 2-stroke Diesel is my favourite engine sound, and that truck in the video is the same model that I actually learned to drive on, a 50's GM twin-stick Detroit.
I took a boot around the back roads in my buddy's old farm truck (same machine) a while back. Boy, I'd forgotten how loud those damned things are and what a lot of work they are to handle. I was pretty pooped (and deaf..) by the time I got back. What a blast!
Here's an old pic of me with a piston from my specialty, the Fairbanks Morse 38D 8 1/8. I kept it as a souvenir when the shop closed up. They purr like the worlds most content pussycat. Valves? We don't need no stinkin' valves! :)
Perhaps not at idle, but have you ever noticed how a turbo'ed slant six sounds like a Cummins diesel? :idea:
All of my slant sixes sounded like diesels; a long-stroke motor with sloppy valves will clatter their way into your heart :biggrin:
Got out that feeler gauge and set that valve lash! :biggrin: Seems like you own/owned all pre-'81, pre-hydraulic lifter slants. ;)
Yep, they all had solids. I had that procedure down to a science, but it was still a pain in the a**, and never really helped much. Not for very long at least. Think I've still got a spare cover gasket somewhere. I've got guitar cases that are shorter than the box that those gaskets came in....:rolleyes:
When I was in my teens my buddy's grandfather taught me the proper (and best) way to do it; drop the idle to as low as it would go (retarding the timing a bunch often helped), then pull the valve cover and do the adjustments while it's running. Once you've got the sequence, it's a piece of cake. Other than some old British singles, I've never seen an engine that could idle as low as the Liberace, haha!
