ron-c said:This impedance miss match may result in a slightly rising frequency response but I doubt it is audible. The whole point of high output MCs is they can be used with a MM phono stage.
The Denons will work well here.
Thanks,
Ron-C
If you're OCD about this, look for the DB Systems kit they sold years ago for matching capacitance and resistance for both MM and MC cartridges. When it was made, it retailed for about $50, I think, and it was two "Y" connectors that plugged into your phono preamp: The bottom of the "Y" went into the phono preamp, one side of the top of the "Y" took the input from your tone arm, and the other top of the "Y" took a colour-coded plug that would change/adjust either the resistance or capacitance.Calypte said:Sorry to continue to hammer on this, Ron, but posts in another forum suggest that the mismatch is a serious issue. One person suggested diving into the preamp to change the value of resistors in the phono section. I've never owned an MC cartridge before, but I'm considering buying a Denon DL-160. I guess I'm still a child of the early 1960s, when MM was all we had. I have a C29 preamp.
Vinyl Rules! said:If you're OCD about this, look for the DB Systems kit they sold years ago for matching capacitance and resistance for both MM and MC cartridges.
You are not the first person to praise the phono section of the C28 here (and in other groups).ehoove said:[snip] I feel the Phono section in the C28 is slightly better.
Good luck!
1. I think you are a wise man to not try to mod the phono section of the C29.Calypte said:Thank you for the replies. I have no intention of modifying the interior of my C29, though I'd be interested if someone could optimize Phono 2 for a high-output MC (but I'm not going to do the work). Right now I'm running a Stanton 881 MkIIs in a Linn Basik Plus arm on an LP12. The sound is (IMHO) really great. The issue is that genuine stereohedron styli for this cartridge are getting hard to find, though www.kabusa.com has some. So I've started to think about other carts, and the high-output MCs sound interesting. I'm told (by some) that the Basik Plus arm doesn't handle MCs very well, but opinion seems to be divided on the suitability of something like the DL-160 in this arm.
I bought the cart based upon the recommendation in this article, which I think was about 11 or 12 years ago. A lot has changed since then, including the fact that Stanton no longer makes this cart and genuine styli are getting difficult to find. I can only rely on what Kevin at www.kabusa.com has told me, but according to him the 881 styli available at a few DJ sources are elliptical, not stereohedron, and the QA became much less reliable after the mid-1990s, with a lot of bent cantilevers and tilted styli. The sound of the original cartridge is great, though.Vinyl Rules! said:4. Doug Sax thinks very highly of the Stanton 881 MKIIS and made a comment in an interview in The Absolute Sound a while back that he thought it was the best sounding cartridge he'd ever listened to. As always, YMMV.![]()
