Hi All -
Maybe a quick answer to this, but I couldn't find it searching through old threads ...
My MR71 is cosmetically challenged, and the transformer case is all rusted out. I picked up a good looking 043-344 from someone parting out an MR71.
Going to swap them, I am confused as I've found an extra pair of leads which are continuous in the replacement transformer. Can anyone tell me where these go?
Here's the schematic of the MR71 power supply (this seems to be consistent from early MR71 which use T123-133A transformers to later MR71 which use 043-344, although I can't find the serial number for the change) ... my serial # is 43B00:
Here's my original transformer in situ:
Note that there is only 1 pair of black leads, which go to the AC power input:
Here's the replacement:
Note that there are 2 pairs of black leads ... there is continuity across the plain black to white striped leads, and continuity across the red striped to green striped leads (hard to spot the green in the pic).
So the question is ... in the replacement transformer, which pair of black leads do I hook up to the AC input? Where do I put the other pair? Did I get the wrong transformer?
Thanks!
Thanks!
