kevzep
Its all about the Music
Definitely sounds a lot like what mine would do. I'd go ahead and replace the LO transistor.I put @Gregory ’s MR80 into my basement shop system a couple of weeks ago. I have an antenna feed for my receiver down there to an attic antenna. There was some scrolling but I was able to lock in stations. SQ is very good. All functions worked as expected. After a few days of using it, the scrolling returned. I tried swapping the plug polarity and changing the fast/slow scan function. There is an audible click as the the LED scrolls.
Today I opened it up and unplugged the RCA. The scroll slowed up bit hear the presets but continued to run…..so I may have matched my skill set on this diagnosis. I will power down, wait a bit then reseat the IC’s to try again.
I reseated IC's until I was blue in the face, and every time I did it I thought, "oh thats better", only to have the same symptom return.
The more you use it and the longer its on, the worse it will get.
