*******UPDATE*******
Now that the engine is back in the car (well, has been since last year), I have had time to put the MR80 back on the bench.
New Zealand is locked down hard due to Covid, so today two weeks in, it was a day dedicated to the MR80.
To re-cap this problem.
The display will randomly scroll very fast, it has a fair amount of instability. The actual tuner will stay on the station its tuned to.
Here's what I did today.
I checked all the power supplies focussing on the +/- 5VDC which runs the Frequency Counter assembly.
I could not find any issues here. I even ran the Frequency Counter Assembly off my very clean bench supply to fully eliminate a supply issue.
I then checked the 200khz Oscillator, then followed the frequency dividers, base calculators and so forth, I just could not find any issues here.
As I started to run through the rest of the testing procedure for the Frequency Counter assembly. I could not find anything wrong, yet there it was, the display unstable, and then randomly scrolling.
How the frequency counter driver works is it receives the Carrier Frequency + 10.7mhz (Intermediate Frequency). This is from the Oscillator + Buffer with carrier wave. It then goes through a 3 stage buffer and then into some dividers and multipliers and other mysterious cmos chips and then drives the display to read the right number.
Part of the testing procedure is to unplug the RCA plug which comes from the Oscillator in the Front end circuit and short the plug out. This then makes the display read a nominal number they call the test pre-load number.
Now, as soon as I disconnected that plug, the display stopped scrolling and being unstable.
It read the 89.3 as it was supposed to, and solid as a rock.
The next few processes came up fine as well.
Then I read that to test the display you could inject a Carrier Wave into the input of the Frequency counter board and it should read your carrier wave "XXmhz" - 10.7mhz.
So I tried this, and at first it wasn't working, because I didn't really know how much level it was going to take to drive the circuit.
This is where it gets interesting.
As I increased level it got to a point where it started influencing the display, but it wasn't accurate, and the display was unstable, and I thought for a minute it might have been the triple line receiver chip they use as a buffer, but I thought, what the heck, I started increasing the level, and it got to a point of threshold where all of a sudden the display snapped into the number it was supposed to be reading.
I was injecting 100.7mhz to get a reading of 90mhz on the display, and it was reading 90.0 mhz solid. I had my spectrum analyser on the input of the Frequency counter driver circuit, and I took this and verified the three gain stages in the triple line receiver and this was all stable and working correctly.
I then swept through the entire range the frequency readout can do, and it was all working nicely.
I thought, right, it's not the Frequency Counter circuit. We need to possibly work back into the IF stage and check this oscillator output.
As soon as I plugged the oscillator back in, the display went crazy again. I wanted to look at this on the scope, but its not really possible to do this as the scope loads the circuit and pulls the signal right down, however I could see it on my spectrum analyser, but it was't able to show me how "noisy" the signal was, it only really shows there is a signal present.
I wasn't able to ascertain if the signal was clean or not, so I decided to replace the oscillator transistor. As luck would have it, I work on a lot of tuners and I had a suitable replacement, it had more HFE, but I thought that shouldn't be an issue, which is wasn't, its just an oscillator.
So I pulled the original transistor and put it on the tester and it came up quite a bit lower in HFE than it is spec'd.
Anyway I fitted the replacement, and WOO HOO, IMMEDIATELY it started working properly!!
I then decided to do a full alignment on the MR80, so that took about 4 hours, there is a LOT to aligning a MR80, during the entire time, not one glitch or anything dodgy happening with the display.
I have been listening to it for over an hour and a half, its still fine. The Auto scan works, the main tuning works, but I have some issue with preset 2 and 4, but I am not concerned with that right now, I will diagnose that tomorrow, but I think I might need some of Patrice's gold springs.
But the presets that work and hold the frequencies now, and they never used to.
So I am going to leave the MR80 running overnight and see where its at in the morning.
I'll also tickle up the IF alignment in the morning too.
It does sound better than it ever has, but I think I can get it a bit better, I reckon I can get the THD a bit lower.
So here we are, right where I thought I would never be with this thing, its been in bits in my Lab for about 12 months.
Anyway, progress may have been made so we will see.
Fingers crossed, and if it does seem that this problem is fixed, I'll jump on that thread and update it.
Interesting to note, right at the beginning, Terry suggested the 5V may have been noisy or dirty causing the circuit to play up.
He was very close, looks like a dirty Local oscillator signal.....
Ferrari Side Strake Heaven!!
My car is the one in the middle.....
