But the new Tektronix scopes are disposable scopes. They are not repairable in the sense that the 400 series scopes are. The problem is custom ICs and surface mounted devices. The new scopes are loaded with them and the ICs (or in many cases just replacement boards) can only be sourced through Tektronix. When they drop support in 7 years or so, and they run out of boards that is the end of the scope. Seen it happen all too often. Do some research before you buy.
There is one feature that the 400 series has than few modern scopes have and that is a channel A output. Some very neat setups and amazing scope channel sensitivity can be realized by cascading channels. Imagine having a frequency counter and scope display done with a single scope probe attachment. That sort of setup is handy when troubleshooting mixers in tuners.
You do what you want, but I would not have a new digital Tektronix scope.
The 465 would likely be more than sufficient for your needs.
The link below says this:
"Used digital scopes that have problems are virtually unrepairable." Which means that once support goes away for a new one, it is scrap.
http://reviews.ebay.com/Buying-an-Oscilloscope-on-ebay?ugid=10000000001568756
You have been warned.
Sorry for the rather brash statements but oscilloscopes are something I happen to know something about. I was in the the used test equipment biz for a while.
If you want a hot setup, get a 475 with the DM44 option. The LED display will look cool. Not the most useful option IMO for audio work, but it looks nice. The DM44 is really nice for measuring timing events.
Richard
