MX117.MC7150
Listener
Gregory will have an MR80 SM Mon or Wed, depending on the PO.
Check the power supply board, cap may be going bad putting humm on the 5V and upsetting the level converter in the counter module.
I would measure all the supply voltages. A scope would be good. A service manual for the MR80 is another must.
I wonder if any replacements for those digital chips are available?
Hopefully that is not the problem....
Yes all the parts are available.
To be honest, I prefer troubleshooting a digital circuits opposed to a to a high impedance very low signal RF analog circuits. It takes some special considerations when dealing with low level mixers, etc.
If I were you I would send it to Terry. He will go through the whole thing and it will perform better than new.
At this point in time it could be anything that is wrong. From an IC to a weak transistor to a bypass cap.
There is more to it than just sticking a scope probe onto an IC. There are some things that show up that are important and a lot of things that don't mean anything. Learning the difference between the two takes time.
A good scope is essential. I prefer the older Tektronix like the 465. They are repairable, reliable and not expensive.
Hello Greg
You can't dammage a screw like this one is you use the right screw driver (whatever it is tight ). Many people use cruciform type for posidriv screws and this is not a good idea ! cruciform type should be use for cruciform and posidriv screw driver for posidrive screws nothing else
You can't damage a screw like this one is you use the right screw driver (whatever it is tight ).
Regarding the color of the screws I don't think that they are original type because they are black . Normaly IIRC... all the screws (big) for all pcb's are not black (ground contact will not be good enough with black screws much better to use "silver "type , contact will not be corroded ). Only the small one are black (power supply board on the left and pcb with the AUDIO output connectors (long pcb) .
The screws for the IF cover are not black too and they are magnetic .
Regarding the recap procedure, If I good remember there is 3 cap of 22MF /6V radial (C103/C104/C124)
