Daniel4381
there is no ground wire in thorens td160, the ground scheme is internally done.Connect a wire from your turntable internal ground to your phono amplifier case and another to the case of your amplifier, then show us a picture. Please. BTW, don't use rca grounds instead of case grounds. Drill a hole in the case if you must to put in a self tapping screw to make these connections. The only time this did not work for me was when I had a bad connection between a wire and the crimp on connector.
this is how the phono stage is connected, shown in the diagram.
