coylum
Well-Known Member
As mentioned in previous threads I have just constructed the first of two Mullard Twenty Watt amplifiers using Transcendar output transformers similar to ones which I have successfully used previously in the Mullard 5-10 circuits.
When checking sine and square wave response I discovered a resonance peak at 79KHz and some ringing on the 5KHz square wave which was largely removed by increasing the NFB network capacitor C9 from 330pF to 398pF. During this process I also ran the amp with no NFB compensating capacitor and oscillation, at 79KHz, occurred with no input and the gain control turned to zero. The oscillation had a magnitude of around 4.8v rms across an 8Ω resistive load. I found this very worrying as it indicates a major potential for instability even when the NFB compensation capacitor is in place?
I would appreciate comments and advice on how to address this issue so as to have an adequate stability margin. Ideally I want to stay as close as possible to the original Mullard specification but equally I do want to make these Transcendar OPT’s function correctly with a margin of safety.
I have detailed below in chronological order the tests and adjustments I have made so far – I have also attached the schematic.
Malcolm
- Negative feedback: -30db specified; Measured open loop gain 64.7dB – Closed loop 35.4dB Actual NFB using 5.6KΩ/330pF equals 29.3dB
- Frequency response: 1 watt, open loop -2dB points 50Hz to 10KHz; Closed loop (5.6KΩ/330pF) ±0.25dB 10Hz to 20KHz, -1.6dB at 100KHz but with small peak at 80KHz +0.7dB.
- Square wave performance: With NFB 5.6KΩ/330pF 5KHz – ringing evident both top and bottom. Increasing to 398pF appeared to remove ringing (see later) but frequency response dropped to -0.5dB at 20KHz (was -0.25db) and -3dB at 100KHz. The resonant peak seemed to have gone.
- Two adjustments made to layout and component values elsewhere: The EL34 cathode capacitors were relocated from the tagboard to direct pin connections on the valve bases to remove them from the heat of the cathode resistors. The relative values of R12 and R11 were adjusted to make R12 nearly 3% higher than R11 yet still within 5% of the nominal 180KΩ value (183KΩ and 178KΩ respectively) as this is suggested for optimal balance by Mullard.
- Whilst preparing to finalise frequency response readings with 5.6KΩ/398pF NFB compensation I noticed the ringing on the 5Khz square wave was back as well as the resonant peak at 80KHz. Could the above mods cause this?
- Whilst preparing to further increase C9 I observed that with no capacitor in place the amplifier was oscillating at 79KHz with no input and the gain control set to zero. The oscillation had an amplitude of 4.8V rms across 8Ω resistive load and increased in amplitude if the gain control was advanced.
Malcolm
