A tube is required for the RCA out connections. The balanced outputs don't use the tube.
Enjoy!
Enjoy!
If I connect this unit dirctly to a power amp will the volume control the XLR or RCA outputs? thanks.
Thanks for the review of the op amp mod. There are alternating opinions on the value of the discrete modification. When added to the cost of the MH it may not compare to buying a higher spec dac in the first place?
What makes the trade better is to use audiogd discrete op amps which are much less expensive than the burson.
Shout to Stout!
I looked at the audiogd website and did not find these op amps. Could you link us up? They will work in the music hall 25.3 dac, won't they?
