I believe you and I talked already on WBF, but yes I definitely am aware of that and I treat all my gear the same way, I never hot swap cables but I appreciate your heads up and I’m glad yours is good after you thought it had a problem.One piece of advice about the NuVista Vinyl: never plug in or unplug any of the inputs with it switched on. I did and ended up with four inputs not working. That was part of the reason why I had it such a long time before using it. Deciding it was time to send it off for repair, I tried it and it worked again! A prolonged period of being off must have allowed some charge on the input board to dissipate. I'm a bit paranoid about that now, but since things are set up I hope there will be no need for swapping connections now.
