Musicality vs. Accuracy?
Even musical instruments aren't necessarily accurate, which would of course impact the accuracy of the music produced. Same holds true of the artist's interpretation of the music - is it exactly what the writer envisioned? Even if the production and playback equipment is "perfect", the chances of us hearing it perfectly are exceedingly small.
Short version - enjoy what you're hearing, or keep trying.
I would think that all accurate systems should sound very close to the same. Musical systems are all over the map and defined differently for everyone. A recording can be accurate and musical at the same time and should be the goal when recording. Most of the world finds the boots and cats and boots and cats sound appealing anyway.
Esthetics, yes... but what's ultimately important is that it sounds pleasing... pleasant, nice.. good. If it is pleasing what ever other terms are used just says it in a different way. I know.. what's pleasing to one might not be pleasing to another, which is why the general agreement that if it sounds good to you it is good. I've heard many systems that don't do this or can't do that but do in fact sound pleasing... to me that is a good and decent system.
- I think this question pervades many of the discussions on this forum, in general. I don't think there is a right or wrong answer, but it does define how people enjoy their gear.
- It seems like accuracy means specs on a piece of paper. If one is using their ear to decide what is accurate, that is purely subjective and inaccurate, to say the least. And what was mentioned earlier seems exactly correct. Each room has its own sound and acoustical dynamics. Just because the specs say one thing doesn't mean the room is obligated to agree with them.
- I agree with the system remarks made on this thread. No component operates in a vacuum. They all work together to make the sound we hear. Speakers are the literal voice of the system. A perfect amp cannot make bad speakers sound good. But good speakers have the ability to make lots of gear sound better (assuming the gear is decent to begin with.)
- I look at specs when selecting gear. I want to be assured that I don't need to concern myself with bad performance in the context of the source. before I ever bring it home. After that, I simply want to enjoy music. There is no way around whatever recording producers and engineers have decided what we should hear. But adjusting their preferences, here and there, to what I like is part of it for me. If I'm not enjoying the music, nothing else matters.
Your results may vary.
A system is only as good as it's weakest link so it's silly to look at the amp in isolation. It's the entire system makes sound.
I initially chased accuracy and it was boring as he'll, then straight musicality. Neither quite did the trick. Since then I've chased transparency and musicality. Seems to have done the trick. :)
Basically you need a blend of each for it to be worthwhile.
You're imposing your own definition of Musical. I happen to agree with it, but that's not the point.
Thats fair and objective I suppose. And do you think politicians will ever be on the same page debating an idea? lol, good point though.
I could care less about the numbers, as long as it sounds "right". Don't even care all that much as to whether it sounds "right" to anyone else ... It's my system and my ears, right? ;-}
I wouldn't limit things to just the amp either, whether it be tube or SS. Every little bit has to be able to play well with everything else in the audio chain. I'd like to say I had a master plan when I started out, but it's mostly pure dumb luck as to how it all worked out ... but no complaints, eh.
Eh? What you say about spitting a hare?
I guess there IS something to say about accuracy when it comes to what you're hearing!
Or would that be "definition? ... hmmmmmm ... ;-}
All things reasonably considered, it would be least likely that I'd blame the amplifier if I wasn't liking what I was hearing.
I've several "keeper" amps with varying degrees of both and distinctively individual characters. I've also some "good" amps I've never warmed to that just don't "draw" me into the music that could easily go away.
Off topic, but “ musicality” reminds me of Booger Mcfarland on Monday Night Football. He says “physicality” at least 50 times a game. I think I know what Booger is referring to and there may be some correlation with the term musicality. Easier to interpret than to explain. I
